Pouvez vous ajouter ce micromodule 2 relais avec neutre ?
Lien vers le site marchand : ici
Configuration JSON Brut :
"ieee": "84:fd:27:ff:fe:8c:47:27",
"nwk": 3930,
"status": 2,
"lqi": "127",
"rssi": "-78",
"last_seen": "1623788850.9587088",
"node_descriptor": "01:40:8e:02:10:52:52:00:00:2c:52:00:00",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 256,
"profile_id": 260,
"manufacturer": "_TYZB01_zsl6z0pw",
"model": "TS0003",
"output_clusters": [
"id": 25,
"name": "Ota",
"attributes": []
"id": 10,
"name": "Time",
"attributes": []
"input_clusters": [
"id": 0,
"name": "Basic",
"attributes": [
"id": 0,
"name": "zcl_version",
"value": 3
"id": 1,
"name": "app_version",
"value": 65
"id": 2,
"name": "stack_version",
"value": 0
"id": 3,
"name": "hw_version",
"value": 1
"id": 4,
"name": "manufacturer",
"value": "_TYZB01_zsl6z0pw"
"id": 5,
"name": "model",
"value": "TS0003"
"id": 6,
"name": "date_code",
"value": ""
"id": 7,
"name": "power_source",
"value": 1
"id": 4,
"name": "Groups",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": []
"id": 6,
"name": "On\/Off",
"attributes": [
"id": 0,
"name": "on_off",
"value": 0
"id": 16385,
"name": "on_time",
"value": 0
"id": 16386,
"name": "off_wait_time",
"value": 0
"id": 2,
"status": 1,
"device_type": 256,
"profile_id": 260,
"manufacturer": null,
"model": null,
"output_clusters": [],
"input_clusters": [
"id": 4,
"name": "Groups",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": []
"id": 6,
"name": "On\/Off",
"attributes": [
"id": 0,
"name": "on_off",
"value": 0
"id": 16385,
"name": "on_time",
"value": 0
"id": 16386,
"value": 0
"signature": {
"model": "TS0003",
"node_desc": {
"byte1": 1,
"byte2": 64,
"mac_capability_flags": 142,
"manufacturer_code": 4098,
"maximum_buffer_size": 82,
"maximum_incoming_transfer_size": 82,
"server_mask": 11264,
"maximum_outgoing_transfer_size": 82,
"endpoints": {
"1": {
"profile_id": 260,
"device_type": 256,
"input_clusters": [
0,
4,
5,
6
25,
10
"2": {
"profile_id": 260,
"device_type": 256,
"input_clusters": [
4,
5,
6
"class": "zigpy.device"
Image du module :
Logs:
[2021-06-16 00:03:38][DEBUG] : {"devices":{"84:fd:27:ff:fe:8c:47:27":{"1":{"6":[{"value":"Bool.false","cluster_name":"On\/Off"}]}}}}
[2021-06-16 00:03:38][DEBUG] : Search attribut for 84:fd:27:ff:fe:8c:47:27 logicalId : 1::6::0 => Bool.false
[2021-06-16 00:03:40][DEBUG] : {"devices":{"84:fd:27:ff:fe:8c:47:27":{"1":{"6":[{"value":"Bool.true","cluster_name":"On\/Off"}]}}}}
[2021-06-16 00:03:40][DEBUG] : Search attribut for 84:fd:27:ff:fe:8c:47:27 logicalId : 1::6::0 => Bool.true
[2021-06-16 00:04:47][DEBUG] : {"devices":{"84:fd:27:ff:fe:8c:47:27":{"2":{"6":[{"value":"Bool.true","cluster_name":"On\/Off"}]}}}}
[2021-06-16 00:04:47][DEBUG] : Search attribut for 84:fd:27:ff:fe:8c:47:27 logicalId : 2::6::0 => Bool.true
[2021-06-16 00:04:50][DEBUG] : {"devices":{"84:fd:27:ff:fe:8c:47:27":{"1":{"6":[{"value":"Bool.false","cluster_name":"On\/Off"}]},"2":{"6":[{"value":"Bool.false","cluster_name":"On\/Off"}]}}}}
[2021-06-16 00:04:50][DEBUG] : Search attribut for 84:fd:27:ff:fe:8c:47:27 logicalId : 1::6::0 => Bool.false
[2021-06-16 00:04:50][DEBUG] : Search attribut for 84:fd:27:ff:fe:8c:47:27 logicalId : 2::6::0 => Bool.false
[2021-06-16 00:04:54][DEBUG] : {"devices":{"84:fd:27:ff:fe:8c:47:27":{"1":{"6":[{"value":"Bool.true","cluster_name":"On\/Off"}]},"2":{"6":[{"value":"Bool.true","cluster_name":"On\/Off"}]}}}}
[2021-06-16 00:04:54][DEBUG] : Search attribut for 84:fd:27:ff:fe:8c:47:27 logicalId : 1::6::0 => Bool.true
[2021-06-16 00:04:54][DEBUG] : Search attribut for 84:fd:27:ff:fe:8c:47:27 logicalId : 2::6::0 => Bool.true
[2021-06-16 00:04:56][DEBUG] : {"devices":{"84:fd:27:ff:fe:8c:47:27":{"1":{"6":[{"value":"Bool.false","cluster_name":"On\/Off"}]}}}}
[2021-06-16 00:04:56][DEBUG] : Search attribut for 84:fd:27:ff:fe:8c:47:27 logicalId : 1::6::0 => Bool.false
[2021-06-16 00:04:56][DEBUG] : {"devices":{"84:fd:27:ff:fe:8c:47:27":{"1":{"6":[{"value":"Bool.true","cluster_name":"On\/Off"}]}}}}
[2021-06-16 00:04:56][DEBUG] : Search attribut for 84:fd:27:ff:fe:8c:47:27 logicalId : 1::6::0 => Bool.true
[2021-06-16 00:04:57][DEBUG] : {"devices":{"84:fd:27:ff:fe:8c:47:27":{"2":{"6":[{"value":"Bool.false","cluster_name":"On\/Off"}]}}}}
[2021-06-16 00:04:57][DEBUG] : Search attribut for 84:fd:27:ff:fe:8c:47:27 logicalId : 2::6::0 => Bool.false
[2021-06-16 00:04:58][DEBUG] : {"devices":{"84:fd:27:ff:fe:8c:47:27":{"2":{"6":[{"value":"Bool.true","cluster_name":"On\/Off"}]}}}}
[2021-06-16 00:04:58][DEBUG] : Search attribut for 84:fd:27:ff:fe:8c:47:27 logicalId : 2::6::0 => Bool.true
[2021-06-16 00:04:59][DEBUG] : {"devices":{"84:fd:27:ff:fe:8c:47:27":{"2":{"6":[{"value":"Bool.false","cluster_name":"On\/Off"}]}}}}
[2021-06-16 00:04:59][DEBUG] : Search attribut for 84:fd:27:ff:fe:8c:47:27 logicalId : 2::6::0 => Bool.false
[2021-06-16 00:05:30][DEBUG] : {"devices":{"84:fd:27:ff:fe:8c:47:27":{"1":{"6":[{"value":"Bool.false","cluster_name":"On\/Off"}]}}}}
[2021-06-16 00:05:30][DEBUG] : Search attribut for 84:fd:27:ff:fe:8c:47:27 logicalId : 1::6::0 => Bool.false
Fabricant : Tuya
Ref : QS-Zigbee-S04-2C-LN
merci.
