Ajout lampe LIDL [TS0505B] Ampoule connectée E27 RGB
Bonjour @Loic
Serait il possible SVP d’ajouter ce module zigbee ?
Livarno Lux E27 - Ampoule connectée ZigBee
    "ieee": "0c:43:14:ff:fe:84:e4:5e",
    "nwk": 37311,
    "status": 2,
    "lqi": "255",
    "rssi": "-55",
    "last_seen": "1648898591.1888103",
    "node_descriptor": "01:40:8e:02:10:52:52:00:00:2c:52:00:00",
    "endpoints": [
            "id": 1,
            "status": 1,
            "device_type": 269,
            "profile_id": 260,
            "manufacturer": "_TZ3000_qd7hej8u",
            "model": "TS0505B",
            "output_clusters": [
                    "id": 25,
                    "name": "Ota",
                    "attributes": []
                    "id": 10,
                    "name": "Time",
                    "attributes": []
            "input_clusters": [
                    "id": 0,
                    "name": "Basic",
                    "attributes": [
                            "id": 0,
                            "name": "zcl_version",
                            "value": 3
                            "id": 1,
                            "name": "app_version",
                            "value": 65
                            "id": 2,
                            "name": "stack_version",
                            "value": 0
                            "id": 3,
                            "name": "hw_version",
                            "value": 1
                            "id": 4,
                            "name": "manufacturer",
                            "value": "_TZ3000_qd7hej8u"
                            "id": 5,
                            "name": "model",
                            "value": "TS0505B"
                            "id": 6,
                            "name": "date_code",
                            "value": ""
                            "id": 7,
                            "name": "power_source",
                            "value": 1
                    "id": 3,
                    "name": "Identify",
                    "attributes": []
                    "id": 4,
                    "name": "Groups",
                    "attributes": []
                    "id": 5,
                    "name": "Scenes",
                    "attributes": []
                    "id": 6,
                    "name": "On\/Off",
                    "attributes": [
                            "id": 0,
                            "name": "on_off",
                            "value": 1
                    "id": 4096,
                    "name": "LightLink",
                    "attributes": []
                    "id": 8,
                    "name": "Level control",
                    "attributes": [
                            "id": 0,
                            "name": "current_level",
                            "value": 65
                    "id": 768,
                    "name": "Color Control",
                    "attributes": [
                            "id": 3,
                            "name": "current_x",
                            "value": 0
                            "id": 4,
                            "name": "current_y",
                            "value": 0
                            "id": 7,
                            "name": "color_temperature",
                            "value": 153
            "id": 242,
            "status": 1,
            "device_type": 97,
            "profile_id": 41440,
            "manufacturer": null,
            "model": null,
                    "id": 33,
                    "name": "GreenPowerProxy",
                    "attributes": []
            "input_clusters": []
    "signature": {
        "model": "TS0505B",
        "node_desc": {
            "logical_type": 1,
            "reserved": 0,
            "aps_flags": 0,
            "frequency_band": 8,
            "mac_capability_flags": 142,
            "manufacturer_code": 4098,
            "maximum_buffer_size": 82,
            "maximum_incoming_transfer_size": 82,
            "server_mask": 11264,
            "maximum_outgoing_transfer_size": 82,
        "endpoints": {
            "1": {
                "profile_id": 260,
                "device_type": 269,
                "input_clusters": [
                    0,
                    3,
                    4,
                    5,
                    6,
                    4096,
                    8,
                    768
                    25,
                    10
            "242": {
                "device_type": 97,
                "input_clusters": [],
                    33
    "class": "zigpy.device"
Merci d’avance
Cordialement
Visiblement le nécessaire a été fait le 26/04
https://compatibility.jeedom.com/index.php?v=d&p=home&search=&plugin=zigbee
A clôturer si OK
Edit : @Loic pourquoi l’avoir classer dans les devices Tuya au lieu de Lidl ?
C’est sûrement une erreur après ça change rien lidl ne fait que rebadger le carton.
Sauf pour le user lambda qui ne trouvera dans la liste des devices Lidl que l’ancien modèle [TS0505A]
Oui oui comme dit je vais corriger mais cela n’a aucun impact sur l’utilisation du produit
Je suis un user lambda… je ne vois pas de TS0505B pour le Fabricant « Lidl »…
Merci de votre aide,
Lila
