Ajout interrupteur aqara WRS-R02
je viens d’acheter un inter double aqara WRS-02
https://www.domotique-store.fr/domotique/usages/domotique-alarme-securite/telecommandes-domotique/1532-xiaomi-aqara-wrs-r02-interrupteur-double-bouton-emetteur-mural-zigbee-ultraplat-a-pile.html
voici les info brut:
    "ieee": "54:ef:44:10:00:06:5c:b4",
    "nwk": 41259,
    "status": 2,
    "lqi": "148",
    "rssi": "-63",
    "last_seen": "1629910040.964159",
    "node_descriptor": "02:40:80:5f:11:7f:64:00:00:2c:64:00:00",
    "endpoints": [
            "id": 1,
            "status": 1,
            "device_type": 259,
            "profile_id": 260,
            "manufacturer": "LUMI",
            "model": "lumi.remote.b28ac1",
            "output_clusters": [
                    "id": 3,
                    "name": "Identify",
                    "attributes": []
                    "id": 6,
                    "name": "On\/Off",
                    "attributes": []
            "input_clusters": [
                    "id": 0,
                    "name": "Basic",
                    "attributes": [
                            "id": 0,
                            "name": "zcl_version",
                            "value": 3
                            "id": 1,
                            "name": "app_version",
                            "value": 21
                            "id": 2,
                            "name": "stack_version",
                            "value": 2
                            "id": 3,
                            "name": "hw_version",
                            "value": 1
                            "id": 4,
                            "name": "manufacturer",
                            "value": "LUMI"
                            "id": 5,
                            "name": "model",
                            "value": "lumi.remote.b28ac1"
                            "id": 6,
                            "name": "date_code",
                            "value": "20200907"
                            "id": 7,
                            "name": "power_source",
                            "value": 3
                            "id": 16384,
                            "name": "sw_build_id",
                            "value": "2019"
                    "id": 3,
                    "name": "Identify",
                    "attributes": []
                    "id": 1,
                    "name": "Power Configuration",
                    "attributes": [
                            "id": 32,
                            "name": "battery_voltage",
                            "value": 32
            "id": 2,
            "status": 3,
            "device_type": null,
            "profile_id": null,
            "manufacturer": null,
            "model": null,
            "output_clusters": [],
            "input_clusters": []
            "id": 3,
            "status": 1,
            "device_type": 259,
            "profile_id": 260,
            "model": null,
                    "id": 6,
                    "name": "On\/Off",
                    "attributes": []
            "input_clusters": [
                    "id": 3,
                    "name": "Identify",
                    "attributes": []
            "id": 4,
            "status": 3,
            "profile_id": null,
            "model": null,
            "id": 5,
            "status": 3,
            "profile_id": null,
            "model": null,
            "id": 6,
            "status": 3,
            "profile_id": null,
            "model": null,
    "signature": {
        "node_desc": {
            "logical_type": 2,
            "reserved": 0,
            "aps_flags": 0,
            "frequency_band": 8,
            "mac_capability_flags": 128,
            "manufacturer_code": 4447,
            "maximum_buffer_size": 127,
            "maximum_incoming_transfer_size": 100,
            "server_mask": 11264,
            "maximum_outgoing_transfer_size": 100,
        "endpoints": {
            "1": {
                "profile_id": 260,
                "device_type": 259,
                "input_clusters": [
                    0,
                    3,
                    1
                    3,
                    6
            "2": {
                "profile_id": null,
                "input_clusters": [],
            "3": {
                "profile_id": 260,
                "device_type": 259,
                "input_clusters": [
                    3
                    6
            "4": {
                "profile_id": null,
            "5": {
                "profile_id": null,
            "6": {
                "profile_id": null,
    "class": "zigpy.device"
et le log:
1 appui sur bouton gauche
2 appui sur bouton droit
[2021-08-25 19:18:32][DEBUG] : {"devices":{"54:ef:44:10:00:06:5c:b4":{"1":{"6":{"cmd":[{"value":"2","cluster_name":"On\/Off"},{"value":"[]","cluster_name":"On\/Off"}]}}}}}
[2021-08-25 19:18:32][DEBUG] : Search command for 54:ef:44:10:00:06:5c:b4 logicalId : 1::6::cmd::0 => 2 convert to 2
[2021-08-25 19:18:33][DEBUG] : {"devices":{"54:ef:44:10:00:06:5c:b4":{"1":{"6":{"cmd":[{"value":"2","cluster_name":"On\/Off"},{"value":"[]","cluster_name":"On\/Off"}]}}}}}
[2021-08-25 19:18:33][DEBUG] : Search command for 54:ef:44:10:00:06:5c:b4 logicalId : 1::6::cmd::0 => 2 convert to 2
[2021-08-27 10:55:57][DEBUG] : Data frame: b'3135b1a9112a15b658924a24ab5593499c214f1dd6c59874fed75a8be0607e'
[2021-08-27 10:55:57][DEBUG] : Sending: b'8430fc7e'
[2021-08-27 10:55:57][DEBUG] : Application frame 69 (incomingMessageHandler) received: b'00040106000101000100006f68b63b0bffff03113902'
[2021-08-27 10:55:57][DEBUG] : Received incomingMessageHandler frame with [<EmberIncomingMessageType.INCOMING_UNICAST: 0>, EmberApsFrame(profileId=260, clusterId=6, sourceEndpoint=1, destinationEndpoint=1, options=<EmberApsOption.APS_OPTION_ENABLE_ROUTE_DISCOVERY: 256>, groupId=0, sequence=111), 104, -74, 0x0b3b, 255, 255, b'\x119\x02']
[2021-08-27 10:55:57][DEBUG] : Ignoring message (b'113902') on cluster 6: unknown endpoint or cluster id: 'No cluster ID 0x0006 on (54:ef:44:10:00:06:5c:b4, 1)'
[2021-08-27 10:55:59][DEBUG] : Data frame: b'4135b1a9112a15b658924a24ab5593499c3e431ed6c59874fed7598bae287e'
[2021-08-27 10:55:59][DEBUG] : Sending: b'8520dd7e'
[2021-08-27 10:55:59][DEBUG] : Application frame 69 (incomingMessageHandler) received: b'00040106000101000100007064b53b0bffff03113a02'
[2021-08-27 10:55:59][DEBUG] : Received incomingMessageHandler frame with [<EmberIncomingMessageType.INCOMING_UNICAST: 0>, EmberApsFrame(profileId=260, clusterId=6, sourceEndpoint=1, destinationEndpoint=1, options=<EmberApsOption.APS_OPTION_ENABLE_ROUTE_DISCOVERY: 256>, groupId=0, sequence=112), 100, -75, 0x0b3b, 255, 255, b'\x11:\x02']
[2021-08-27 10:55:59][DEBUG] : Ignoring message (b'113a02') on cluster 6: unknown endpoint or cluster id: 'No cluster ID 0x0006 on (54:ef:44:10:00:06:5c:b4, 1)'
[2021-08-27 10:55:59][DEBUG] : Send command readCounters: ()
[2021-08-27 10:55:59][DEBUG] : Sending: b'153a21a9a52a7d38817e'
[2021-08-27 10:55:59][DEBUG] : Data frame: b'523aa1a9a52a29b241945b25a15593499c4e27abedce6c8bffc66389fc7e3fa7e8cdde6f8fffc7dbd5d2698c4623a9ec763ba5ea758241984c2613b1e070381c0e07bbe5ca658b459a4d9e4f9ff7c3d9d46a35a251904824be017e'
[2021-08-27 10:55:59][DEBUG] : Sending: b'8610be7e'
[2021-08-27 10:55:59][DEBUG] : Application frame 241 (readCounters) received: b'3c00180011000b0001000000000000000b0002000000000000000300000000000000000000000000000000000000000000000000000000000000000000000000010000000000000000000000000000000000'
[2021-08-27 10:55:59][DEBUG] : Send command getValue: (<EzspValueId.VALUE_FREE_BUFFERS: 3>,)
[2021-08-27 10:55:59][DEBUG] : Sending: b'263b21a9fe2a160a5e7e'
[2021-08-27 10:55:59][DEBUG] : Data frame: b'633ba1a9fe2a15b3a250ba7e'
[2021-08-27 10:55:59][DEBUG] : Sending: b'87009f7e'
[2021-08-27 10:55:59][DEBUG] : Application frame 170 (getValue) received: b'0001fb'
[2021-08-27 10:55:59][DEBUG] : Free buffers status EzspStatus.SUCCESS, value: 251
[2021-08-27 10:55:59][DEBUG] : ezsp_counters: [MAC_RX_BROADCAST = 60, MAC_TX_BROADCAST = 24, MAC_RX_UNICAST = 17, MAC_TX_UNICAST_SUCCESS = 11, MAC_TX_UNICAST_RETRY = 1, MAC_TX_UNICAST_FAILED = 0, APS_DATA_RX_BROADCAST = 0, APS_DATA_TX_BROADCAST = 0, APS_DATA_RX_UNICAST = 11, APS_DATA_TX_UNICAST_SUCCESS = 2, APS_DATA_TX_UNICAST_RETRY = 0, APS_DATA_TX_UNICAST_FAILED = 0, ROUTE_DISCOVERY_INITIATED = 0, NEIGHBOR_ADDED = 3, NEIGHBOR_REMOVED = 0, NEIGHBOR_STALE = 0, JOIN_INDICATION = 0, CHILD_REMOVED = 0, ASH_OVERFLOW_ERROR = 0, ASH_FRAMING_ERROR = 0, ASH_OVERRUN_ERROR = 0, NWK_FRAME_COUNTER_FAILURE = 0, APS_FRAME_COUNTER_FAILURE = 0, UTILITY = 0, APS_LINK_KEY_NOT_AUTHORIZED = 0, NWK_DECRYPTION_FAILURE = 0, APS_DECRYPTION_FAILURE = 0, ALLOCATE_PACKET_BUFFER_FAILURE = 0, RELAYED_UNICAST = 0, PHY_TO_MAC_QUEUE_LIMIT_REACHED = 0, PACKET_VALIDATE_LIBRARY_DROPPED_COUNT = 0, TYPE_NWK_RETRY_OVERFLOW = 0, PHY_CCA_FAIL_COUNT = 1, BROADCAST_TABLE_FULL = 0, PTA_LO_PRI_REQUESTED = 0, PTA_HI_PRI_REQUESTED = 0, PTA_LO_PRI_DENIED = 0, PTA_HI_PRI_DENIED = 0, PTA_LO_PRI_TX_ABORTED = 0, PTA_HI_PRI_TX_ABORTED = 0, ADDRESS_CONFLICT_SENT = 0, EZSP_FREE_BUFFERS = 251]
actuellement l’appui sur n’importe quel bouton envoie 2 sur l’info bouton 1
J’ai le même problème. Avez-vous la solution svp ?
