Bonjour, mon plafonnier IKEA n’est pas reconnu par le plugin zigbee. Ci joint les informations requises
IKEA L1528
FLOALT LED light panel, dimmable, white spectrum (30x90 cm)
light (state, brightness, color_temp, color_temp_startup), effect, power_on_behavior, linkquality
Ci joint l’image
et le lien commercial
informations brutes
"ieee": "00:0b:57:ff:fe:37:53:d9",
"nwk": 850,
"status": 2,
"lqi": "255",
"rssi": "-82",
"last_seen": "1633506985.1848927",
"node_descriptor": "01:40:8e:7c:11:52:52:00:00:2c:52:00:00",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 268,
"profile_id": 260,
"manufacturer": "IKEA of Sweden",
"model": "FLOALT panel WS 30x90",
"output_clusters": [
"id": 5,
"name": "Scenes",
"attributes": []
"id": 25,
"name": "Ota",
"attributes": []
"id": 32,
"name": "Poll Control",
"attributes": []
"id": 4096,
"name": "LightLink",
"attributes": []
"input_clusters": [
"id": 0,
"name": "Basic",
"attributes": [
"id": 0,
"name": "zcl_version",
"value": 3
"id": 1,
"name": "app_version",
"value": 33
"id": 2,
"name": "stack_version",
"value": 98
"id": 3,
"name": "hw_version",
"value": 1
"id": 4,
"name": "manufacturer",
"value": "IKEA of Sweden"
"id": 5,
"name": "model",
"value": "FLOALT panel WS 30x90"
"id": 6,
"name": "date_code",
"value": "20201102"
"id": 7,
"name": "power_source",
"value": 1
"id": 16384,
"name": "sw_build_id",
"value": "2.3.068"
"id": 3,
"name": "Identify",
"attributes": []
"id": 4,
"name": "Groups",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": []
"id": 6,
"name": "On\/Off",
"attributes": [
"id": 0,
"name": "on_off",
"value": 1
"id": 8,
"name": "Level control",
"attributes": []
"id": 768,
"name": "Color Control",
"attributes": []
"id": 4096,
"attributes": []
"id": 64636,
"name": "Manufacturer Specific",
"attributes": []
"id": 242,
"status": 1,
"device_type": 97,
"profile_id": 41440,
"manufacturer": null,
"model": null,
"id": 33,
"name": "GreenPowerProxy",
"attributes": []
"input_clusters": [
"id": 33,
"attributes": []
"signature": {
"node_desc": {
"logical_type": 1,
"reserved": 0,
"aps_flags": 0,
"frequency_band": 8,
"mac_capability_flags": 142,
"manufacturer_code": 4476,
"maximum_buffer_size": 82,
"maximum_incoming_transfer_size": 82,
"server_mask": 11264,
"maximum_outgoing_transfer_size": 82,
"endpoints": {
"1": {
"profile_id": 260,
"device_type": 268,
"input_clusters": [
0,
3,
4,
5,
6,
8,
768,
4096,
64636
5,
25,
32,
4096
"242": {
"device_type": 97,
"input_clusters": [
33
33
"class": "zigpy.device"
Je ne peux pas agir sur la lumière car je n’ai pas de telecommande pour la faire fonctionner
J’ai essayer de mettre l’équipement float panel WS 30x30 mais cela ne fonctionne pas
Ce module remonte correctement dans zigbeet2mqtt si cela peut aider
Merci de me tenir au courant et si besoin d’autres infos
Cordialement
