Aide pour mise en forme widget
Je viens de passer mon jeedom en debian 11/4.4.19, et globalement j’ai réussi à résoudre tous mes petits soucis d’affichage, sauf 1.
J’ai un widget de températures qui me résiste. Le voici:
<div class="cmd cmd-widget #history#" data-type="info" data-subtype="numeric" data-template="tile" data-cmd_id="#id#"
  data-cmd_uid="#uid#" data-version="#version#" data-eqLogic_id="#eqLogic_id#">
    Jeedom Compatibility: v4.4.5
  <div class="title #hide_name#">
  </div>
  <div class="content">
    <div class="left"></div>
    <div class="right">
      <div class="valDetail">
        <span class="value state"></span>
        <br>
        <span class="unit"></span>
        <div class="cmdName">#name_display#</div>
      </div>
      <div class="cmdStats #hide_history#">
        <span title="{{Minimum}}" class="tooltips">Min : #minHistoryValue#</span>
        <span title="{{Moyenne}}" class="tooltips">Moy : #averageHistoryValue#</span>
        <span title="{{Maximum}}" class="tooltips">Max : #maxHistoryValue#</span>
        <span class="tendance" title="{{Tendance}}" class="tooltips">Tendance : <i class="#tendance#"></i></span>
      </div>
    </div>
  </div>
  <div class="timeCmd label label-default #history#" data-type="info"></div>
  <template>
    <div>time : duration|date ({{Affiche durée ou date de la valeur}})</div>
  </template>
  <style>
    div.cmd.cmd-widget[data-cmd_id="#id#"][data-type="info"][data-subtype="numeric"][data-template="tile"] .state {
      font-size: 1em !important;
    [data-cmd_id="#id#"] .cmd-widget {
      width: 120px;
      display: block !important;
    [data-cmd_id="#id#"] .content {
      padding: 0px;
      width: 50px;
      height: 50px;
    [data-cmd_id="#id#"] .left {
      float: left;
    [data-cmd_id="#id#"] .right {
      text-align: left;
      padding-left: 0px;
    [data-cmd_id="#id#"] .valDetail {
      padding-bottom: 0px;
      text-align: center !important;
      width: 80px !important;
    [data-cmd_id="#id#"] .valDetail span.value {
      font-size: 15px !important;
    [data-cmd_id="#id#"] .cmdStats span {
      display: block;
    [data-cmd_id="#id#"] .tendance {
      padding-top: 1px;
  </style>
  <script>
    jeedom.cmd.addUpdateFunction('#id#', function (_options) {
      if (is_object(cmd = document.querySelector('.cmd[data-cmd_uid="#uid#"]'))) {
        cmd.querySelector('.content').setAttribute('title', '{{Date de valeur}}: ' + _options.valueDate + '<br>{{Date de collecte}}: ' + _options.collectDate)
        if ('#time#' == 'duration' || '#time#' == 'date') {
          jeedom.cmd.displayDuration(_options.valueDate, cmd.querySelector('.timeCmd'), '#time#')
        if (is_numeric(_options.value)) {
          cmd.querySelector('.value').innerHTML = _options.display_value
          cmd.querySelector('.unit').innerHTML = _options.unit
        } else {
          cmd.querySelector('.value').innerHTML = '<span class="label label-danger">' + _options.value + '</span>'
        if (_options.alertLevel == 'warning') {
          cmd.querySelector('.value').innerHTML = '<span class="label label-warning"><i class="fas fa-bell"></i> ' + _options.value + '</span>'
        } else if (_options.alertLevel == 'danger') {
          cmd.querySelector('.value').innerHTML = '<span class="label label-danger"><i class="fas fa-exclamation"></i> ' + _options.value + '</span>'
        let valeur = (parseFloat(_options.display_value).toFixed(1) - parseInt(_options.display_value)) === 0 ? parseInt(_options.display_value) : parseFloat(_options.display_value).toFixed(1);
        if (valeur <= 0) {
          imgNumber = '00';
        } else if (valeur > 0 && valeur <= 5) {
          imgNumber = '01';
        } else if (valeur > 5 && valeur <= 10) {
          imgNumber = '02';
        } else if (valeur > 10 && valeur <= 13) {
          imgNumber = '03';
        } else if (valeur > 13 && valeur <= 16) {
          imgNumber = '04';
        } else if (valeur > 16 && valeur <= 18) {
          imgNumber = '05';
        } else if (valeur > 18 && valeur <= 20) {
          imgNumber = '06';
        } else if (valeur > 20 && valeur <= 22) {
          imgNumber = '07';
        } else if (valeur > 22 && valeur <= 24) {
          imgNumber = '08';
        } else if (valeur > 24 && valeur <= 26) {
          imgNumber = '09';
        } else if (valeur > 26 && valeur <= 28) {
          imgNumber = '10';
        } else if (valeur > 28 && valeur <= 34) {
          imgNumber = '11';
        } else {
          imgNumber = '12';
        cmd.querySelector('.left').innerHTML = '<img style="height: 40px;margin-top:10px!important;width: 12px;" src="data/img/thermometer' + imgNumber + '.png"></img>';
    jeedom.cmd.refreshValue([{ cmd_id: '#id#', value: '#value#', display_value: '#state#', valueDate: '#valueDate#', collectDate: '#collectDate#', alertLevel: '#alertLevel#', unit: '#unite#' }])
  </script>
</div>
En image, cela donne:
temp-44
C’est moche!
Je voudrais:
  • décaler un peu le texte sur la droite
  • modifier la police de EXTERIEUR (qui doit être géré par
    #name_display#
    . J’ai crée une classe perso, mais je ne parviens pas à faire ce que je veux.
  • Diminuer la taille du °C
En gros, pour le rendre comme en 4.3:
IMG_0801
Si vous voulez bien m’aider, ça serait sympa. Merci à tous.
Tu peux tester cette version :
<div class="cmd cmd-widget #history#" data-type="info" data-subtype="numeric" data-cmd_id="#id#" data-cmd_uid="#uid#" data-version="#version#" data-eqLogic_id="#eqLogic_id#">
    <div>
      <div class="right">
          <br>
          <div class="title #hide_name#"><div class="cmdName ">#name_display#</div></div>
        </div>
      </div>
    </div>
      <span title="{{Tendance}}" class="tooltips tendance">Tendance : <i class="#tendance#"></i></span>
    </div>
  </div>
  <template>
  </template>
  <style>
    [data-cmd_id="#id#"] .content img {
      height: 40px;
      width: 12px;
    [data-cmd_id="#id#"] .content > div:first-of-type {
      display: inline-flex;
      align-items: center;
    [data-cmd_id="#id#"] .state {
      font-size: 12px !important;
      line-height: 12px !important;
    [data-cmd_id="#id#"] .cmdName {
      font-weight: 600 !important;
      font-size: 10px !important;
    [data-cmd_id="#id#"] .unit {
    [data-cmd_id="#id#"] .left, [data-cmd_id="#id#"] .right {
      margin: 5px;
      display: block;
      padding-top: 1px;
  </style>
  <script>
        } else {
        if (valeur <= 0) {
          imgNumber = '00';
        } else if (valeur <= 5) {
          imgNumber = '01';
        } else if (valeur <= 10) {
          imgNumber = '02';
        } else if (valeur <= 13) {
          imgNumber = '03';
        } else if (valeur <= 16) {
          imgNumber = '04';
        } else if (valeur <= 18) {
          imgNumber = '05';
        } else if (valeur <= 20) {
          imgNumber = '06';
        } else if (valeur <= 22) {
          imgNumber = '07';
        } else if (valeur <= 24) {
          imgNumber = '08';
        } else if (valeur <= 26) {
          imgNumber = '09';
        } else if (valeur <= 28) {
          imgNumber = '10';
        } else if (valeur <= 34) {
          imgNumber = '11';
        } else {
          imgNumber = '12';
        cmd.querySelector('.left').innerHTML = '<img src="data/img/thermometer' + imgNumber + '.png"></img>';
  </script>
</div>
Merci :blush:
Je teste ca dès demain
J’ai testé et c’est top, merci beaucoup :slight_smile:
J’ai modifié la taille de la class CmdName pour mettre le nom encore plus petit:
Dernière petite question: sur mon design, je redimensionne ma tuile pour que les images soient les unes au dessus des autres, mais j’ai des décalages. Cela vient du widget ou bien de mon virtuel directement?
Tu as un décalage car le widget s’adapte au contenu, il faudrait ajouter un min-width a la div « right »
Merci à toi. Voici donc le code final (j’ai séparé les div left et right par rapport au code précédent):
    <div>
      <div class="right">
          <br>
        </div>
      </div>
    </div>
    </div>
  </div>
  <template>
  </template>
  <style>
      height: 40px;
      width: 12px;
      font-size: 6px !important;
      margin: 5px;
      margin: 5px;
      min-width: 40px !important;
      display: block;
      padding-top: 1px;
  </style>
  <script>
        } else {
        if (valeur <= 0) {
          imgNumber = '00';
          imgNumber = '01';
          imgNumber = '02';
          imgNumber = '03';
          imgNumber = '04';
          imgNumber = '05';
          imgNumber = '06';
          imgNumber = '07';
          imgNumber = '08';
          imgNumber = '09';
          imgNumber = '10';
          imgNumber = '11';
        } else {
          imgNumber = '12';
  </script>
</div>
Et le rendu final:
Encore merci pour ton aide, c’est parfait :slight_smile:
