Pouvez vous m’aider à interpréter les messages d’erreur apparus dans le log de googlecast ce matin? Merci par avance.
/var/www/html/plugins/googlecast/resources/googlecast.py:2186: DeprecationWarning: The 'warn' function is deprecated, use 'warning' instead
logging.warn("SCANNER------Seen as connected but ping failed for " + known)
[2021-04-08 20:19:52][ERROR] : SENDER------Error on send request to jeedom, return code 500
[2021-04-10 20:38:46][ERROR] : SENDER------Error on send request to jeedom, return code 500
[2021-04-10 20:42:30][ERROR] : SENDER------Error on send request to jeedom, return code 500
[2021-04-10 20:42:54][ERROR] : SENDER------Error on send request to jeedom, return code 500
[2021-04-10 20:43:02][ERROR] : SENDER------Error on send request to jeedom, return code 500
