Bonjour à tous , j’ai fait back up rpi4 Raspbian GNU/Linux 10 (buster) 32bits (armv7l) et installé sur fresh install rpi5 rasbian 12 , je n’arrive pas à me connecté à ma mon rpi5 aprés le back up :
# Cette page ne fonctionne pas
Impossible de traiter cette demande via **192.168.1.247** à l'heure actuelle.
HTTP ERROR 500
le log HTTP est :
[Fri Jan 31 10:28:07.400498 2025] [php:error] [pid 106299:tid 106299] [client 192.168.1.154:54253] PHP Fatal error: Uncaught Error: Class "ajax" not found in /var/www/html/core/ajax/log.ajax.php:68
Stack trace:
#0 {main}
thrown in /var/www/html/core/ajax/log.ajax.php on line 68
[Fri Jan 31 10:28:07.400498 2025] [php:error] [pid 105531:tid 105531] [client 192.168.1.154:54282] PHP Fatal error: Uncaught Error: Class "ajax" not found in /var/www/html/core/ajax/event.ajax.php:36
Stack trace:
#0 {main}
thrown in /var/www/html/core/ajax/event.ajax.php on line 36
[Fri Jan 31 10:28:08.391904 2025] [php:error] [pid 3231953:tid 3231953] [client 192.168.1.154:54289] PHP Fatal error: Uncaught Error: Class "ajax" not found in /var/www/html/core/ajax/log.ajax.php:68
Stack trace:
#0 {main}
[Fri Jan 31 10:28:08.391946 2025] [php:error] [pid 106302:tid 106302] [client 192.168.1.154:54290] PHP Fatal error: Uncaught Error: Class "ajax" not found in /var/www/html/core/ajax/event.ajax.php:36
Stack trace:
#0 {main}
[Fri Jan 31 10:28:09.416336 2025] [php:error] [pid 106282:tid 106282] [client 192.168.1.154:54291] PHP Fatal error: Uncaught Error: Class "ajax" not found in /var/www/html/core/ajax/log.ajax.php:68
Stack trace:
#0 {main}
[Fri Jan 31 10:28:09.416583 2025] [php:error] [pid 1913699:tid 1913699] [client 192.168.1.154:54292] PHP Fatal error: Uncaught Error: Class "ajax" not found in /var/www/html/core/ajax/event.ajax.php:36
Stack trace:
#0 {main}
[Fri Jan 31 10:28:43.691997 2025] [php:warn] [pid 106299:tid 106299] [client 192.168.1.154:54301] PHP Warning: Undefined variable $productName in /var/www/html/desktop/php/administration.php on line 618
[Fri Jan 31 10:29:51.831457 2025] [php:error] [pid 1533334:tid 1533334] [client 192.168.1.154:54317] PHP Fatal error: Uncaught TypeError: array_multisort(): Argument #1 ($array) must be an array or a sort flag in /var/www/html/desktop/php/index.php:92
Stack trace:
#0 /var/www/html/desktop/php/index.php(92): array_multisort()
#1 /var/www/html/core/php/utils.inc.php(79): require_once('...')
#2 /var/www/html/index.php(100): include_file()
#3 {main}
thrown in /var/www/html/desktop/php/index.php on line 92, referer: http://192.168.1.247/index.php?v=d&p=administration
[Fri Jan 31 10:30:20.577167 2025] [php:error] [pid 3250089:tid 3250089] [client 192.168.1.154:54326] PHP Fatal error: Uncaught TypeError: array_multisort(): Argument #1 ($array) must be an array or a sort flag in /var/www/html/desktop/php/index.php:92
Stack trace:
#3 {main}
[Fri Jan 31 10:31:59.994402 2025] [php:error] [pid 106299:tid 106299] [client 192.168.1.154:54345] PHP Fatal error: Uncaught TypeError: array_multisort(): Argument #1 ($array) must be an array or a sort flag in /var/www/html/desktop/php/index.php:92
Stack trace:
#3 {main}
[Fri Jan 31 10:32:51.434779 2025] [php:warn] [pid 106301:tid 106301] [client 192.168.1.154:54346] PHP Warning: Undefined array key "extension" in /var/www/html/core/php/downloadFile.php on line 95, referer: http://192.168.1.247/index.php?v=d&p=log&rescue=1
[Fri Jan 31 10:34:47.236826 2025] [access_compat:error] [pid 1913699:tid 1913699] [client 192.168.1.207:62478] AH01797: client denied by server configuration: /var/www/html/currentsetting.htm
sh: 1: cannot create /etc/resolv.conf: Permission denied
[Fri Jan 31 10:52:49.221571 2025] [access_compat:error] [pid 1913699:tid 1913699] [client 192.168.1.207:64926] AH01797: client denied by server configuration: /var/www/html/currentsetting.htm
je ne vois pas d’ou vient l’erreur , j’avais désactivé tout les pluggin avant le backup pour pouvoir garder ma pagination sur le RPI5 , j’aimerai bien retrouvé ma config sur mon rpi5.
Merci à tout ceux qui pourrons me venir en aide
