Kerje
Novembre 29, 2019, 10:25
1
Je viens d’inclure la Siren6 d’Aeotec (ZW164) à mon jeedom. Cette dernière n’est malheuresement pas reconnue. Après avoir parcouru plusieurs forums, je me rends compte que le souci est déjà largement commenté.
J’ai quand meme remarqué que la définition de cette sirène apparait dans la branche « Master » d’Open ZWave depuis 4 mois:
Aeotec ZW164 Indoor Siren 6
<Product Revision="2" xmlns="https://github.com/OpenZWave/open-zwave">
<MetaData>
<MetaDataItem name="OzwInfoPage">http://www.openzwave.com/device-database/0086:00a4:0003</MetaDataItem>
<MetaDataItem name="ProductPic">images/aeotec/zw164.png</MetaDataItem>
<MetaDataItem id="00a4" name="Identifier" type="0003">ZW164-C</MetaDataItem>
<MetaDataItem id="00a4" name="ZWProductPage" type="0003">https://products.z-wavealliance.org/products/3301/</MetaDataItem>
<MetaDataItem id="00a4" name="FrequencyName" type="0003">CEPT (Europe)</MetaDataItem>
<MetaDataItem id="00a4" name="Identifier" type="0103">ZW164-A</MetaDataItem>
<MetaDataItem id="00a4" name="ZWProductPage" type="0103">https://products.z-wavealliance.org/products/3284/</MetaDataItem>
<MetaDataItem id="00a4" name="FrequencyName" type="0103">U.S. / Canada / Mexico</MetaDataItem>
<MetaDataItem name="WakeupDescription"></MetaDataItem>
<MetaDataItem name="InclusionDescription">This product supports Security 2 Command Class. While a Security S2 enabled Controller is needed in order to fully use the security feature. This product can be included and operated in any Z-Wave network with other Z-Wave certified devices from other manufacturers and/or other applications. All non-battery operated nodes within the network will act as repeaters regardless of vendor to increase reliability of the network. 1. Set your Z-Wave Controller into its 'Add Device' mode in order to add Chime into your Z-Wave system. Refer to the Controller's manual if you are unsure of how to perform this step. 2. Power on Chime via the provided power adapter; its LED will be breathing white light all the time. 3. Click Chime Action Button once, it will quickly flash white light for 30 seconds until Chime is added into the network. It will become constantly bright white light after being assigned a NodeID. 4. If your Z-Wave Controller supports S2 encryption, enter the first 5 digits of DSK into your Controller's interface if/when requested. The DSK is printed on Chime's housing. 5. If Adding fails, it will slowly flash white light 3 times and then become breathing white light; repeat steps 1 to 4. Contact us for further support if needed. 6. If Adding succeeds, it will quickly flash white light 3 times and then become off. Now, Chime is a part of your Z-Wave home control system. You can configure it and its automations via your Z-Wave system; please refer to your software's user guide for precise instructions. Note: If Action Button is clicked again during the Learn Mode, the Learn Mode will exit. At the same time, Indicator Light will extinguish immediately, and then become breathing white light.</MetaDataItem>
<MetaDataItem name="Name">Indoor Siren 6</MetaDataItem>
<MetaDataItem name="ExclusionDescription">1. Set your Z-Wave Controller into its ' Remove Device' mode in order to remove Chime from your Z-Wave system. Refer to the Controller's manual if you are unsure of how to perform this step. 2. Power on Chime via the provided power adapter; its LED will be off. 3. Click Chime Action Button 6 times quickly; it will bright white light, up to 2s. 4. If Removing fails, it will keep off; repeat steps 1 to 3. Contact us for further support if needed. 5. If Removing succeeds, it will quickly flash white light 3 times and then become breathing white light. Now, Chime is removed from Z-Wave network successfully.</MetaDataItem>
<MetaDataItem name="Description">- S2 Security. - Not only a siren, but also can be used as a doorbell via setting. - Can be wireless controlled by more Button, up to 3. - Longer Button control distance, up to 120m. - Built-in multiple tones, up to 30. - Built-in multiple adjustable Light Effect.</MetaDataItem>
<MetaDataItem name="ResetDescription">If the primary controller is missing or inoperable, you may need to reset the device to factory settings. Make sure the Chime is powered. To complete the reset process manually, press and hold the Action Button for at least 20s. The LED indicator will quickly flash white light 3 times and then become breathing white light, which indicates the reset operation is successful. Otherwise, please try again. Contact us for further support if needed. Note: 1. This procedure should only be used when the primary controller is missing or inoperable. 2. Factory Reset Chime will: (a) Remove Chime from Z-Wave network; (b) Delete the Association setting; (c) Restore the configuration settings to the default.(Except configuration parameter 51/52/53/54)</MetaDataItem>
This file has been truncated. show original
Y aurai-t-il un moyen d’inclure la sirène manuellement ?
Merci d’avance
oui comme ici : Add metadata for aeotec indoor siren 6 by GeertvanHorrik · Pull Request #1894 · OpenZWave/open-zwave · GitHub
1 - tu mets le fichier XML dans ton plugin openzwave,
2 - tu ajoute la ligne sur le fichier manufacturer_specific.xml
3 - tu ajoutes l’image jpg
4 - tu ajoutes le fichier .json (en faisant un copier d’exemple de commande) ou sinon on les rentrant à la main comme ici https://www.jeedom.com/forum/viewtopic.php?f=34&t=45110&start=40#p759599
tu redémarre les démon tu fais un synchroniser et c’est ok
Hunter
Décembre 2, 2019, 5:09
3
this solution works properly.
system
A fermé ce sujet ()
Décembre 4, 2019, 3:58
4
