Json :
"ieee": "60:a4:23:ff:fe:8c:de:4a",
"nwk": 36127,
"status": 2,
"lqi": "255",
"rssi": "-52",
"last_seen": "1618485028.9496584",
"node_descriptor": "01:40:8e:77:12:52:52:00:00:2c:52:00:00",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 269,
"profile_id": 260,
"manufacturer": "Adeo",
"model": "LXEK-1",
"output_clusters": [
"id": 25,
"name": "Ota",
"attributes": []
"input_clusters": [
"id": 0,
"name": "Basic",
"attributes": [
"id": 0,
"name": "zcl_version",
"value": 3
"id": 1,
"name": "app_version",
"value": 1
"id": 2,
"name": "stack_version",
"value": 2
"id": 3,
"name": "hw_version",
"value": 1
"id": 4,
"name": "manufacturer",
"value": "Adeo"
"id": 5,
"name": "model",
"value": "LXEK-1"
"id": 6,
"name": "date_code",
"value": "20200526"
"id": 7,
"name": "power_source",
"value": 1
"id": 16384,
"name": "sw_build_id",
"value": "2.4.0"
"id": 3,
"name": "Identify",
"attributes": []
"id": 4,
"name": "Groups",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": []
"id": 6,
"name": "On\/Off",
"attributes": [
"id": 0,
"name": "on_off",
"value": 1
"id": 8,
"name": "Level control",
"attributes": [
"id": 0,
"name": "current_level",
"value": 221
"id": 768,
"name": "Color Control",
"attributes": [
"id": 3,
"name": "current_x",
"value": 20427
"id": 4,
"name": "current_y",
"value": 21476
"id": 7,
"name": "color_temperature",
"value": 153
"id": 4096,
"name": "LightLink",
"attributes": []
"id": 64642,
"name": "Manufacturer Specific",
"attributes": []
"id": 242,
"status": 1,
"device_type": 97,
"profile_id": 41440,
"manufacturer": null,
"model": null,
"id": 33,
"name": "GreenPowerProxy",
"attributes": []
"input_clusters": []
"signature": {
"model": "LXEK-1",
"node_desc": {
"byte1": 1,
"byte2": 64,
"mac_capability_flags": 142,
"manufacturer_code": 4727,
"maximum_buffer_size": 82,
"maximum_incoming_transfer_size": 82,
"server_mask": 11264,
"maximum_outgoing_transfer_size": 82,
"endpoints": {
"1": {
"profile_id": 260,
"device_type": 269,
"input_clusters": [
0,
3,
4,
5,
6,
8,
768,
4096,
64642
25
"242": {
"device_type": 97,
"input_clusters": [],
33
"class": "zigpy.device"
Par default lors de l’inclusion le Step des curseurs est réglé à 0.5, cela provoque donc des erreur sur les commandes Luminosité et Température de couleur, un passage à Step 1 dans les paramètres optionnel du widget permet de ne plus avoir d’erreur.
Cela peut-il est pris en compte des le départ ?
Je teste que 2 ampoules sur Zigbee et le soucis est présent sur les 2, un problème général ?
