Actualisation valeurs FGBS-222
J’ai changé depuis peu mon module FGBS-222 qui gère ma piscine (température et pompe).
Mais je me suis aperçu que les valeurs ne s’actualise pas.
Je suis obligé d’aller dans le configuration du module et de cliquer sur « forcé la mise à jour » pour faire remonté la valeur.
Ci-dessous la configuration de mon module, qui normmalement devrait d’actualiser.
Avez-vous une idée, j’ai surement loupé quelque chose mais je vois pas.
Index 	Nom 	Type 	Valeur 	Modifier 	Aide
20 	Input 1 operating mode 	List 	Monostable button
This parameter allows to choose mode of 1st input (IN1). Change it depending on connected device.
21 	Input 2 operating mode 	List 	Monostable button
This parameter allows to choose mode of 2nd input (IN2). Change it depending on connected device.
24 	Inputs orientation 	List 	Default (IN1 - 1st input, IN2 - 2nd input)
This parameter allows reversing operation of IN1 and IN2 inputs without changing the wiring. Use in case of incorrect wiring.
25 	Outputs orientation 	List 	Default (OUT1 - 1st output, OUT2 - 2nd output)
This parameter allows reversing operation of OUT1 and OUT2 inputs without changing the wiring. Use in case of incorrect wiring.
40 	Input 1 sent scenes 	Byte 	0
This parameter defines which actions result in sending scene ID and attribute assigned to them. Parameter is relevant only if parameter 20 is set to 2 or 3. bitmask. 0 => No scenes sent. 1 => Key pressed 1 time. 2 => Key pressed 2 times. 4 => Key pressed 3 times. 8 => Key hold down and key released.
41 	Input 2 sent scenes 	Byte 	0
This parameter defines which actions result in sending scene ID and attribute assigned to them. Parameter is relevant only if parameter 21 is set to 2 or 3. bitmask. 0 => No scenes sent. 1 => Key pressed 1 time. 2 => Key pressed 2 times. 4 => Key pressed 3 times. 8 => Key hold down and key released.
47 	Input 1 value sent to 2nd association group when activated 	Short 	255
This parameter defines value sent to devices in 2nd association group when IN1 input is triggered (using Basic Command Class). Available settings: 0-255. Default setting: 255.
49 	Input 1 value sent to 2nd association group when deactivated 	Short 	0
This parameter defines value sent to devices in 2nd association group when IN1 input is deactivated (using Basic Command Class). Available settings: 0-255. Default setting: 255.
52 	Input 2 value sent to 3rd association group when activated 	Short 	255
This parameter defines value sent to devices in 3rd association group when IN2 input is triggered (using Basic Command Class). Available settings: 0-255. Default setting: 255.
54 	Input 2 value sent to 3rd association group when deactivated 	Short 	0
This parameter defines value sent to devices in 3rd association group when IN2 input is deactivated (using Basic Command Class). Available settings: 0-255. Default setting: 255.
63 	Analog inputs minimal change to report 	Byte 	1
This parameter defines minimal change (from the last reported) of analog input value that results in sending new report. Parameter is relevant only for analog inputs (parameter 20 or 21 set to 4 or 5). Available settings: 0 - (reporting on change disabled). 1-100 (0.1-10V, 0.1V step). Default setting: 5 (0.5V).
64 	Analog inputs periodical reports 	Short 	0
This parameter defines reporting period of analog inputs value. Periodical reports are independent from changes in value (parameter 63). Parameter is relevant only for analog inputs (parameter 20 or 21 set to 4 or 5). Available settings: 0 (periodical reports disabled). 60-32400 (60s-9h). Default setting: 0 (periodical reports disabled).
65 	Internal temperature sensor minimal change to report 	Short 	1
This parameter defines minimal change (from the last reported) of internal temperature sensor value that results in sending new report. Available settings: 0 - (reporting on change disabled). 1-255 (0.1-25.5C). Default setting: 5 (0.5C).
66 	Internal temperature sensor periodical reports 	Short 	300
This parameter defines reporting period of internal temperature sensor value. Periodical reports are independent from changes in value (parameter 65). Available settings: 0 (periodical reports disabled). 60-32400 (60s-9h). Default setting: 0 (periodical reports disabled).
67 	External sensors minimal change to report 	Short 	2
This parameter defines minimal change (from the last reported) of external sensors values (DS18B20 or DHT22) that results in sending new report. Parameter is relevant only for connected DS18B20 or DHT22 sensors. Available settings: 0 - (reporting on change disabled). 1-255 (0.1-25.5 units). Default setting: 5 (0.5 units)
68 	External sensors periodical reports 	Short 	300
This parameter defines reporting period of analog inputs value. Periodical reports are independent from changes in value (parameter 67). Parameter is relevant only for connected DS18B20 or DHT22 sensors. Available settings: 0 - (periodical reports disabled). 60-32400 (60s-9h). Default setting: 0 (periodical reports disabled).
150 	Input 1 sensitivity 	Byte 	10
This parameter defines the inertia time of IN1 input in alarm modes. Adjust this parameter to prevent bouncing or signal disruptions. Parameter is relevant only if parameter 20 is set to 0 or 1 (alarm mode). Available settings: 1-100 (10ms-1000ms, 10ms step). Default setting: 10 (100ms).
151 	Input 2 sensitivity 	Byte 	10
This parameter defines the inertia time of IN2 input in alarm modes. Adjust this parameter to prevent bouncing or signal disruptions. Parameter is relevant only if parameter 21 is set to 0 or 1 (alarm mode). Available settings: 1-100 (10ms-1000ms, 10ms step). Default setting: 10 (100ms).
152 	Input 1 delay of alarm cancellation 	Short 	0
This parameter defines additional delay of cancelling the alarm on IN1 input. Parameter is relevant only if parameter 20 is set to 0 or 1 (alarm mode). Available settings: 0 - no delay. 1-3600s. Default setting: 0 (no delay).
153 	Input 2 delay of alarm cancellation 	Short 	0
This parameter defines additional delay of cancelling the alarm on IN2 input. Parameter is relevant only if parameter 21 is set to 0 or 1 (alarm mode). Available settings: 0 - no delay. 1-3600s. Default setting: 0 (no delay).
154 	Output 1 logic of operation 	List 	contacts normally open
This parameter defines logic of OUT1 output operation.
155 	Output 2 logic of operation 	List 	contacts normally open
This parameter defines logic of OUT2 output operation.
156 	Output 1 auto off 	Short 	5
This parameter defines time after which OUT1 will be automatically deactivated. Available settings: 0 - auto off disabled. 1-27000 (0.1s-45min, 0.1s step). Default setting: 0 (auto off disabled).
157 	Output 2 auto off 	Short 	5
This parameter defines time after which OUT2 will be automatically deactivated. Available settings: 0 - auto off disabled. 1-27000 (0.1s-45min, 0.1s step). Default setting: 0 (auto off disabled).
Merci d’avance de vos retours.
Twin
Si possible, essaye d’exclure puis d’inclure ton module avec ton contrôleur à proximité (moins de 3 m).
Quelles sont les valeurs qui ne s’actualisent plus ?
In ?
Out ?
Température ?
Peux-tu encadrer avec la balise </>
C’est les températures que j’utilise, mais il me semble que rien ne s’actualise.
Instance 4 Index 1
Instance 6 Index 1
Instance 7 Index 1
Les tensions et également ne semble pas bouger.
Les entrées je ne les utilises pas, les sorties fonctionne avec mon scénario.
Pour information j’ai eu énormément de difficulté pour arriver à voir les sondes de températures qui remonte. J’ai 2 sondes ds18b20. J’ai du faire de nombreuses exclusion, RAZ du module puis inclusion pour pouvoir voir des valeurs.
As-tu défini un refresh à 5 minutes dans les paramètres du module onglet valeur (? pour la température) ?
Screenshot_20220727-222013
Alors c’est en automatique pour la température :
Mais dans les paramètres en effet j’ai défini à 300s donc 5min
Merci de prendre du temps pour m’aider.
Et bien essai de mettre 5mn comme sur ma capture à la place de Auto
Merci Bison, effectivement quand je met le paramètre à 5min cela fonctionne.
Je me pose la question de l’utilité du paramètre 68 :thinking:
J’ai une autre question, connais tu la conso maxi du module ?
Car il est sur batterie 7HAh avec des panneaux solaire qui charge la batterie à 100% chaque mais elle ne semble pas tenir la nuit.
Je soupçonne un pb sur la batterie.
Il faut alimenter le module entre 9 et 30V DC et il peut sortir 150mA maximum sur ces sorties alors je ne sais pas combien il consomme mais bon, disons peut être bien 150mA maximum :upside_down_face:.
Oui ok pour la tension, il me semble que c’est le pouvoir de coupure qui est de 150mA.
Je pense aussi que la conso varie en fonction de ce qui est branché.
Pas grave je réouvrirais un sujet sur le sujet au cas ou.
