J ai fais la mise a jour en début d après midi. et ca a marcher du feu de dieu. tout les fonction et capture ainsi que les scenario ( j ai un scenario notamment qui prend une capture toute les heures ).
nickel, Verif toute la soirée, au poil!)
Ce matin ca ne marché plus depuis 4 heures du mat avec ce genre d erreur
2021-07-09 08:49:41][ERROR] : KeepAliveThread : during set subscription: Could not get response event after notify
[2021-07-09 08:50:13][ERROR] : KeepAliveThread : during set subscription: Could not get response event after notify
[2021-07-09 08:50:27][INFO] : ConnectionThread : Checking connection status...
[2021-07-09 08:51:59][INFO] : ConnectionThread : Checking connection status...
[2021-07-09 08:52:12][ERROR] : KeepAliveThread : during set subscription: Could not get response event after notify
[2021-07-09 08:52:43][ERROR] : KeepAliveThread : during set subscription: Could not get response event after notify
[2021-07-09 08:53:31][INFO] : ConnectionThread : Checking connection status...
[2021-07-09 08:54:42][ERROR] : KeepAliveThread : during set subscription: Could not get response event after notify
[2021-07-09 08:55:04][INFO] : ConnectionThread : Checking connection status...
[2021-07-09 08:55:13][ERROR] : KeepAliveThread : during set subscription: Could not get response event after notify
[2021-07-09 08:56:36][INFO] : ConnectionThread : Checking connection status...
[2021-07-09 08:57:12][ERROR] : KeepAliveThread : during set subscription: Could not get response event after notify
[2021-07-09 08:57:44][ERROR] : KeepAliveThread : during set subscription: Could not get response event after notify
[2021-07-09 08:58:09][INFO] : ConnectionThread : Checking connection status...
[2021-07-09 08:59:42][INFO] : ConnectionThread : Checking connection status...
[2021-07-09 08:59:43][ERROR] : KeepAliveThread : during set subscription: Could not get response event after notify
[2021-07-09 09:00:06][INFO] : MainThread : Execute:TakeFullFrameSnapshot
[2021-07-09 09:00:14][ERROR] : KeepAliveThread : during set subscription: Could not get response event after notify
[2021-07-09 09:01:14][INFO] : ConnectionThread : Checking connection status...
[2021-07-09 09:02:13][INFO] : EventHandler : Connection with Arlo lost, re-connecting...
[2021-07-09 09:02:13][INFO] : EventHandler : Disconnect eventstream
[2021-07-09 09:02:14][ERROR] : KeepAliveThread : during set subscription: Could not get response event after notify
[2021-07-09 09:02:14][INFO] : KeepAliveThread : end KeepAlive for A5D1097VA1AF7
[2021-07-09 09:02:16][INFO] : EventHandler : Connect eventstream
[2021-07-09 09:02:20][INFO] : KeepAliveThread : start KeepAlive for A5D1097VA1AF7
J ai redémarre la cam et le demon, c’est repartis. je vous tiens au courant si ca se rebloque.
Ah ca doit dépendre de l’intensité avec laquelle on l’utilise.
J’ai le même scenario (Capture toutes les heures) sur mes arlo pro 3 avec panneau solaire, plus detection de mouvement la nuit et quand l’alarme est mise en journée (environ 5 jours par semaine).
Mes 3 caméras sont à 100% de batteries depuis 4 mois … en Picardie quand même
2021-07-14 23:37:19][ERROR] : KeepAliveThread : during set subscription: HTTPSConnectionPool(host='myapi.arlo.com', port=443): Read timed out. (read timeout=10)
[2021-07-14 23:37:59][ERROR] : KeepAliveThread : during set subscription: HTTPSConnectionPool(host='myapi.arlo.com', port=443): Read timed out. (read timeout=10)
[2021-07-14 23:39:15][ERROR] : KeepAliveThread : during set subscription: HTTPSConnectionPool(host='myapi.arlo.com', port=443): Read timed out. (read timeout=10)
[2021-07-14 23:41:19][ERROR] : KeepAliveThread : during set subscription: HTTPSConnectionPool(host='myapi.arlo.com', port=443): Read timed out. (read timeout=10)
[2021-07-15 00:08:26][ERROR] : KeepAliveThread : during set subscription: Could not get response event after notify
[2021-07-15 01:22:40][ERROR] : KeepAliveThread : during set subscription: HTTPSConnectionPool(host='myapi.arlo.com', port=443): Read timed out. (read timeout=10)
[2021-07-15 01:25:11][ERROR] : KeepAliveThread : during set subscription: Could not get response event after notify
[2021-07-15 02:35:39][ERROR] : KeepAliveThread : during set subscription: Could not get response event after notify
[2021-07-15 02:38:09][ERROR] : KeepAliveThread
voila les erreurs mais j arrive a lancer une capture avec le widget mais pas les scenario.
[2021-07-23 01:11:43][ERROR] : KeepAliveThread : during set subscription: Could not get response event after notify
[2021-07-23 01:14:38][ERROR] : KeepAliveThread : during set subscription: HTTPSConnectionPool(host='myapi.arlo.com', port=443): Read timed out. (read timeout=10)
[2021-07-23 01:24:59][ERROR] : KeepAliveThread : during set subscription: Could not get response event after notify
[2021-07-23 01:25:33][ERROR] : KeepAliveThread : during set subscription: Could not get response event after notify
[2021-07-23 01:37:51][ERROR] : KeepAliveThread : during set subscription: Could not get response event after notify
[2021-07-23 02:20:55][ERROR] : KeepAliveThread : during set subscription: Could not get response event after notify
[2021-07-23 02:25:42][ERROR] : KeepAliveThread : during set subscription: Could not get response event after notify
[2021-07-23 02:28:12][ERROR] : KeepAliveThread : during set subscription: Could not get response event after notify
[2021-07-23 02:30:43][ERROR] : KeepAliveThread : during set subscription: Could not get response event after notify
[2021-07-23 02:33:13][ERROR] : KeepAliveThread : during set subscription: Could not get response event after notify
[2021-07-23 02:35:43][ERROR] : KeepAliveThread : during set subscription: Could not get response event after notify
[2021-07-23 02:38:14][ERROR] : KeepAliveThread : during set subscription: Could not get response event after notify
[2021-07-23 02:40:44][ERROR] : KeepAliveThread : during set subscription: Could not get response event after notify
[2021-07-23 02:43:15][ERROR] : KeepAliveThread : during set subscription: Could not get response event after notify
Edit: je vois, l’erreur a lieu parce qu’il y a eu un timeout coté arlo lors du ping du système pour recevoir les événements.
Ce n’est pas grave que un de temps en temps échoue.
Malgré tout il y en a beaucoup chez vous. est-ce que le réseau wifi est bon? la caméra est en wifi?
quel est la force du signal?
edit2: j’ai changé en beta pour faire un retry en cas d’erreur, cela sera en beta demain.
