A non-numeric value encountered in /var/www/html/vendor/symfony/expression-language/Node/BinaryNode.php on line 142
Box Atlas sous debian 11 Cor 4.4.17 stable
Plugin
Quand le démon tourne voila ce que j’ai dans les logs cron execution
1 ligne a la seconde presque
-------------------- TRUNCATED LOG -------------------- 3702|PHP Warning: A non-numeric value encountered in /var/www/html/vendor/symfony/expression-language/Node/BinaryNode.php on line 142 3703|PHP Warning: A non-numeric value encountered in /var/www/html/vendor/symfony/expression-language/Node/BinaryNode.php on line 142 3704|PHP Warning: A non-numeric value encountered in /var/www/html/vendor/symfony/expression-language/Node/BinaryNode.php on line 142 3705|PHP Warning: A non-numeric value encountered in /var/www/html/vendor/symfony/expression-language/Node/BinaryNode.php on line 142 3706|PHP Warning: A non-numeric value encountered in /var/www/html/vendor/symfony/expression-language/Node/BinaryNode.php on line 142 3707|PHP Warning: A non-numeric value encountered in /var/www/html/vendor/symfony/expression-language/Node/BinaryNode.php on line 142 3708|PHP Warning: A non-numeric value encountered in /var/www/html/vendor/symfony/expression-language/Node/BinaryNode.php on line 142 3709|PHP Warning: A non-numeric value encountered in /var/www/html/vendor/symfony/expression-language/Node/BinaryNode.php on line 142 3710|PHP Warning: A non-numeric value encountered in /var/www/html/vendor/symfony/expression-language/Node/BinaryNode.php on line 142 3711|PHP Warning: A non-numeric value encountered in /var/www/html/vendor/symfony/expression-language/Node/BinaryNode.php on line 142 3712|PHP Warning: A non-numeric value encountered in /var/www/html/vendor/symfony/expression-language/Node/BinaryNode.php on line 142 3713|PHP Warning: A non-numeric value encountered in /var/www/html/vendor/symfony/expression-language/Node/BinaryNode.php on line 142 3714|PHP Warning: A non-numeric value encountered in /var/www/html/vendor/symfony/expression-language/Node/BinaryNode.php on line 142 3715|PHP Warning: A non-numeric value encountered in /var/www/html/vendor/symfony/expression-language/Node/BinaryNode.php on line 142 3716|PHP Warning: A non-numeric value encountered in /var/www/html/vendor/symfony/expression-language/Node/BinaryNode.php on line 142 3717|PHP Warning: A non-numeric value encountered in /var/www/html/vendor/symfony/expression-language/Node/BinaryNode.php on line 142 3718|PHP Warning: A non-numeric value encountered in /var/www/html/vendor/symfony/expression-language/Node/BinaryNode.php on line 142 3719|PHP Warning: A non-numeric value encountered in /var/www/html/vendor/symfony/expression-language/Node/BinaryNode.php on line 142 3720|PHP Warning: A non-numeric value encountered in /var/www/html/vendor/symfony/expression-language/Node/BinaryNode.php on line 142 3721|PHP Warning: A non-numeric value encountered in /var/www/html/vendor/symfony/expression-language/Node/BinaryNode.php on line 142 3722|PHP Warning: A non-numeric value encountered in /var/www/html/vendor/symfony/expression-language/Node/BinaryNode.php on line 142 3723|PHP Warning: A non-numeric value encountered in /var/www/html/vendor/symfony/expression-language/Node/BinaryNode.php on line 142 3724|PHP Warning: A non-numeric value encountered in /var/www/html/vendor/symfony/expression-language/Node/BinaryNode.php on line 142 3725|PHP Warning: A non-numeric value encountered in /var/www/html/vendor/symfony/expression-language/Node/BinaryNode.php on line 142
Il n’y a pas de cron dans le plugin-mymodbus
Possible.
Mais ce log apparait là.
Dès que le démon est stoppé cela s’arrête.
Comme ça génère une ligne a la seconde on s’en apercoit rapidement
Est-il possible qu’un scénario ou qu’un autre équipement écrive ou lise des commandes de MyModbus ?
Il y a un scénario
Mais il teste une commande conso c’est tout
En désactivant ce scénario, est-ce que les erreurs persistent ?
Bien vu en désactivant le scénario plus de log !?
Bon… pour la suite, je ne saurai pas vous aider à corriger (sans doute personne avec juste le petit bout de capture, en fait)
LOL
Ce scénario teste une commande du plugin et ne fait rien d’autre sur les équipements mymodbus
Donc rien que le fait de tester une info d’une commande issue du plugin ca génère le log.
Vous avez le scénario complet donc le petit bout donné montré juste ce qui est utilisé issu du plugin. Y a rien d’autre de plus. Ce n’est pas le scénario du siècle.
Je ne vois pas quoi donner de plus.
Ce scénario n’écrit pas, ne lis pas, comme dit plus haut il teste une commande.
Quant ) la commande testée elle est issue du virtuel ci dessous
Donc a aucun moment il y a lecture ou écriture on ne fait que récupérer valeurs et faire des calculs.
Je crois, mais c’est à tester, que la syntaxe
-(#[une][commande][quelquonque]# - #[une][autre][commande]#)
devrait être remplacée par
(#[une][commande][quelquonque]# - #[une][autre][commande]#) * -1
ou
(#[une][autre][commande]# - #[une][commande][quelquonque]#)
Mais c’est à tester. Peut-être que ça ne résout rien. Je ne suis, et de loin pqs, un spécialiste des expression du plugin virtuel.
Bon, c’est le simple petit scénario qui génère le souci.
Car le test utilise un équipement désactivé que je n’avais pas vu !
Donc le plugin n’est pas en cause.
