Daemon log 2/2
1456|Traceback (most recent call last):
1457|File "/usr/local/lib/python3.7/dist-packages/requests_oauthlib/oauth2_session.py", line 484, in request
1458|url, http_method=method, body=data, headers=headers
1459|File "/usr/local/lib/python3.7/dist-packages/oauthlib/oauth2/rfc6749/clients/base.py", line 217, in add_token
1460|raise TokenExpiredError()
1461|oauthlib.oauth2.rfc6749.errors.TokenExpiredError: (token_expired)
1462|During handling of the above exception, another exception occurred:
1463|Traceback (most recent call last):
1464|File "/usr/local/lib/python3.7/dist-packages/websocket/_app.py", line 424, in _callback
1465|callback(self, *args)
1466|File "/var/www/html/plugins/gardena/resources/gardenad/gardena/ws_client.py", line 57, in _on_close
1467|self._set_connected(False)
1468|File "/var/www/html/plugins/gardena/resources/gardenad/gardena/ws_client.py", line 45, in _set_connected
1469|self._on_connection_callback()
1470|File "/var/www/html/plugins/gardena/resources/gardenad/gardena/smart_system.py", line 288, in
1471|self.gardena_ws_client = WSClient(on_message_callback=self.on_message, on_connection_lost_callback=lambda: self.on_gardena_ws_connection_lost(location=location), level=self.level)
1472|File "/var/www/html/plugins/gardena/resources/gardenad/gardena/smart_system.py", line 340, in on_gardena_ws_connection_lost
1473|self.start_gardena_ws(location)
1474|File "/var/www/html/plugins/gardena/resources/gardenad/gardena/smart_system.py", line 282, in start_gardena_ws
1475|data=json.dumps(args, ensure_ascii=False),
1476|File "/usr/local/lib/python3.7/dist-packages/requests/sessions.py", line 577, in post
1477|return self.request('POST', url, data=data, json=json, **kwargs)
1478|File "/usr/local/lib/python3.7/dist-packages/requests_oauthlib/oauth2_session.py", line 503, in request
1479|self.auto_refresh_url, auth=auth, **kwargs
1480|File "/usr/local/lib/python3.7/dist-packages/requests_oauthlib/oauth2_session.py", line 422, in refresh_token
1481|body=body, refresh_token=refresh_token, scope=self.scope, **kwargs
1482|File "/usr/local/lib/python3.7/dist-packages/oauthlib/oauth2/rfc6749/clients/base.py", line 475, in prepare_refresh_body
1483|refresh_token=refresh_token, **kwargs)
1484|TypeError: prepare_token_request() got multiple values for argument 'grant_type'
1485|During handling of the above exception, another exception occurred:
1486|Traceback (most recent call last):
1487|File "/usr/local/lib/python3.7/dist-packages/requests_oauthlib/oauth2_session.py", line 484, in request
1488|url, http_method=method, body=data, headers=headers
1489|File "/usr/local/lib/python3.7/dist-packages/oauthlib/oauth2/rfc6749/clients/base.py", line 217, in add_token
1490|raise TokenExpiredError()
1491|oauthlib.oauth2.rfc6749.errors.TokenExpiredError: (token_expired)
1492|During handling of the above exception, another exception occurred:
1493|Traceback (most recent call last):
1494|File "/usr/local/lib/python3.7/dist-packages/websocket/_app.py", line 383, in run_forever
1495|dispatcher.read(self.sock.sock, read, check)
1496|File "/usr/local/lib/python3.7/dist-packages/websocket/_app.py", line 66, in read
1497|if not read_callback():
1498|File "/usr/local/lib/python3.7/dist-packages/websocket/_app.py", line 351, in read
1499|return teardown(frame)
1500|File "/usr/local/lib/python3.7/dist-packages/websocket/_app.py", line 318, in teardown
1501|self._callback(self.on_close, close_status_code, close_reason)
1502|File "/usr/local/lib/python3.7/dist-packages/websocket/_app.py", line 429, in _callback
1503|self.on_error(self, e)
1504|File "/var/www/html/plugins/gardena/resources/gardenad/gardena/ws_client.py", line 53, in _on_error
1505|self._set_connected(False)
1506|File "/var/www/html/plugins/gardena/resources/gardenad/gardena/ws_client.py", line 45, in _set_connected
1507|self._on_connection_callback()
1508|File "/var/www/html/plugins/gardena/resources/gardenad/gardena/smart_system.py", line 288, in
1509|self.gardena_ws_client = WSClient(on_message_callback=self.on_message, on_connection_lost_callback=lambda: self.on_gardena_ws_connection_lost(location=location), level=self.level)
1510|File "/var/www/html/plugins/gardena/resources/gardenad/gardena/smart_system.py", line 340, in on_gardena_ws_connection_lost
1511|self.start_gardena_ws(location)
1512|File "/var/www/html/plugins/gardena/resources/gardenad/gardena/smart_system.py", line 282, in start_gardena_ws
1513|data=json.dumps(args, ensure_ascii=False),
1514|File "/usr/local/lib/python3.7/dist-packages/requests/sessions.py", line 577, in post
1515|return self.request('POST', url, data=data, json=json, **kwargs)
1516|File "/usr/local/lib/python3.7/dist-packages/requests_oauthlib/oauth2_session.py", line 503, in request
1517|self.auto_refresh_url, auth=auth, **kwargs
1518|File "/usr/local/lib/python3.7/dist-packages/requests_oauthlib/oauth2_session.py", line 422, in refresh_token
1519|body=body, refresh_token=refresh_token, scope=self.scope, **kwargs
1520|File "/usr/local/lib/python3.7/dist-packages/oauthlib/oauth2/rfc6749/clients/base.py", line 475, in prepare_refresh_body
1521|refresh_token=refresh_token, **kwargs)
1522|TypeError: prepare_token_request() got multiple values for argument 'grant_type'
1523|During handling of the above exception, another exception occurred:
1524|Traceback (most recent call last):
1525|File "/usr/local/lib/python3.7/dist-packages/requests_oauthlib/oauth2_session.py", line 484, in request
1526|url, http_method=method, body=data, headers=headers
1527|File "/usr/local/lib/python3.7/dist-packages/oauthlib/oauth2/rfc6749/clients/base.py", line 217, in add_token
1528|raise TokenExpiredError()
1529|oauthlib.oauth2.rfc6749.errors.TokenExpiredError: (token_expired)
1530|During handling of the above exception, another exception occurred:
1531|Traceback (most recent call last):
1532|File "/usr/local/lib/python3.7/dist-packages/websocket/_app.py", line 424, in _callback
1533|callback(self, *args)
1534|File "/var/www/html/plugins/gardena/resources/gardenad/gardena/ws_client.py", line 53, in _on_error
1535|self._set_connected(False)
1536|File "/var/www/html/plugins/gardena/resources/gardenad/gardena/ws_client.py", line 45, in _set_connected
1537|self._on_connection_callback()
1538|File "/var/www/html/plugins/gardena/resources/gardenad/gardena/smart_system.py", line 288, in
1539|self.gardena_ws_client = WSClient(on_message_callback=self.on_message, on_connection_lost_callback=lambda: self.on_gardena_ws_connection_lost(location=location), level=self.level)
1540|File "/var/www/html/plugins/gardena/resources/gardenad/gardena/smart_system.py", line 340, in on_gardena_ws_connection_lost
1541|self.start_gardena_ws(location)
1542|File "/var/www/html/plugins/gardena/resources/gardenad/gardena/smart_system.py", line 282, in start_gardena_ws
1543|data=json.dumps(args, ensure_ascii=False),
1544|File "/usr/local/lib/python3.7/dist-packages/requests/sessions.py", line 577, in post
1545|return self.request('POST', url, data=data, json=json, **kwargs)
1546|File "/usr/local/lib/python3.7/dist-packages/requests_oauthlib/oauth2_session.py", line 503, in request
1547|self.auto_refresh_url, auth=auth, **kwargs
1548|File "/usr/local/lib/python3.7/dist-packages/requests_oauthlib/oauth2_session.py", line 422, in refresh_token
1549|body=body, refresh_token=refresh_token, scope=self.scope, **kwargs
1550|File "/usr/local/lib/python3.7/dist-packages/oauthlib/oauth2/rfc6749/clients/base.py", line 475, in prepare_refresh_body
1551|refresh_token=refresh_token, **kwargs)
1552|TypeError: prepare_token_request() got multiple values for argument 'grant_type'
1553|During handling of the above exception, another exception occurred:
1554|Traceback (most recent call last):
1555|File "/usr/local/lib/python3.7/dist-packages/requests_oauthlib/oauth2_session.py", line 484, in request
1556|url, http_method=method, body=data, headers=headers
1557|File "/usr/local/lib/python3.7/dist-packages/oauthlib/oauth2/rfc6749/clients/base.py", line 217, in add_token
1558|raise TokenExpiredError()
1559|oauthlib.oauth2.rfc6749.errors.TokenExpiredError: (token_expired)
1560|During handling of the above exception, another exception occurred:
1561|Traceback (most recent call last):
1562|File "/usr/lib/python3.7/threading.py", line 917, in _bootstrap_inner
1563|self.run()
1564|File "/usr/lib/python3.7/threading.py", line 865, in run
1565|self._target(*self._args, **self._kwargs)
1566|File "/usr/local/lib/python3.7/dist-packages/websocket/_app.py", line 386, in run_forever
1567|self._callback(self.on_error, e)
1568|File "/usr/local/lib/python3.7/dist-packages/websocket/_app.py", line 429, in _callback
1569|self.on_error(self, e)
1570|File "/var/www/html/plugins/gardena/resources/gardenad/gardena/ws_client.py", line 53, in _on_error
1571|self._set_connected(False)
1572|File "/var/www/html/plugins/gardena/resources/gardenad/gardena/ws_client.py", line 45, in _set_connected
1573|self._on_connection_callback()
1574|File "/var/www/html/plugins/gardena/resources/gardenad/gardena/smart_system.py", line 288, in
1575|self.gardena_ws_client = WSClient(on_message_callback=self.on_message, on_connection_lost_callback=lambda: self.on_gardena_ws_connection_lost(location=location), level=self.level)
1576|File "/var/www/html/plugins/gardena/resources/gardenad/gardena/smart_system.py", line 340, in on_gardena_ws_connection_lost
1577|self.start_gardena_ws(location)
1578|File "/var/www/html/plugins/gardena/resources/gardenad/gardena/smart_system.py", line 282, in start_gardena_ws
1579|data=json.dumps(args, ensure_ascii=False),
1580|File "/usr/local/lib/python3.7/dist-packages/requests/sessions.py", line 577, in post
1581|return self.request('POST', url, data=data, json=json, **kwargs)
1582|File "/usr/local/lib/python3.7/dist-packages/requests_oauthlib/oauth2_session.py", line 503, in request
1583|self.auto_refresh_url, auth=auth, **kwargs
1584|File "/usr/local/lib/python3.7/dist-packages/requests_oauthlib/oauth2_session.py", line 422, in refresh_token
1585|body=body, refresh_token=refresh_token, scope=self.scope, **kwargs
1586|File "/usr/local/lib/python3.7/dist-packages/oauthlib/oauth2/rfc6749/clients/base.py", line 475, in prepare_refresh_body
1587|refresh_token=refresh_token, **kwargs)
1588|TypeError: prepare_token_request() got multiple values for argument 'grant_type'
1589|[2022-06-13 09:57:53]INFO : Websocket connection close: (1001)-Going away
1590|[2022-06-13 09:57:53]INFO : Restarting websocket...
1591|[2022-06-13 09:57:53]ERROR : error from callback >: prepare_token_request() got multiple values for argument 'grant_type'
1592|[2022-06-13 09:57:53]ERROR : Websocket error: prepare_token_request() got multiple values for argument 'grant_type'
1593|[2022-06-13 09:57:53]INFO : Restarting websocket...
1594|[2022-06-13 09:57:53]ERROR : Websocket error: prepare_token_request() got multiple values for argument 'grant_type'
1595|[2022-06-13 09:57:53]INFO : Restarting websocket...
1596|[2022-06-13 09:57:53]ERROR : error from callback >: prepare_token_request() got multiple values for argument 'grant_type'
1597|[2022-06-13 09:57:53]ERROR : Websocket error: prepare_token_request() got multiple values for argument 'grant_type'
1598|[2022-06-13 09:57:53]INFO : Restarting websocket...
1599|Exception in thread Thread-287:
1600|Traceback (most recent call last):
1601|File "/usr/local/lib/python3.7/dist-packages/requests_oauthlib/oauth2_session.py", line 484, in request
1602|url, http_method=method, body=data, headers=headers
1603|File "/usr/local/lib/python3.7/dist-packages/oauthlib/oauth2/rfc6749/clients/base.py", line 217, in add_token
1604|raise TokenExpiredError()
1605|oauthlib.oauth2.rfc6749.errors.TokenExpiredError: (token_expired)
1606|During handling of the above exception, another exception occurred:
1607|Traceback (most recent call last):
1608|File "/usr/local/lib/python3.7/dist-packages/websocket/_app.py", line 424, in _callback
1609|callback(self, *args)
1610|File "/var/www/html/plugins/gardena/resources/gardenad/gardena/ws_client.py", line 57, in _on_close
1611|self._set_connected(False)
1612|File "/var/www/html/plugins/gardena/resources/gardenad/gardena/ws_client.py", line 45, in _set_connected
1613|self._on_connection_callback()
1614|File "/var/www/html/plugins/gardena/resources/gardenad/gardena/smart_system.py", line 288, in
1615|self.gardena_ws_client = WSClient(on_message_callback=self.on_message, on_connection_lost_callback=lambda: self.on_gardena_ws_connection_lost(location=location), level=self.level)
1616|File "/var/www/html/plugins/gardena/resources/gardenad/gardena/smart_system.py", line 340, in on_gardena_ws_connection_lost
1617|self.start_gardena_ws(location)
1618|File "/var/www/html/plugins/gardena/resources/gardenad/gardena/smart_system.py", line 282, in start_gardena_ws
1619|data=json.dumps(args, ensure_ascii=False),
1620|File "/usr/local/lib/python3.7/dist-packages/requests/sessions.py", line 577, in post
1621|return self.request('POST', url, data=data, json=json, **kwargs)
1622|File "/usr/local/lib/python3.7/dist-packages/requests_oauthlib/oauth2_session.py", line 503, in request
1623|self.auto_refresh_url, auth=auth, **kwargs
1624|File "/usr/local/lib/python3.7/dist-packages/requests_oauthlib/oauth2_session.py", line 422, in refresh_token
1625|body=body, refresh_token=refresh_token, scope=self.scope, **kwargs
1626|File "/usr/local/lib/python3.7/dist-packages/oauthlib/oauth2/rfc6749/clients/base.py", line 475, in prepare_refresh_body
1627|refresh_token=refresh_token, **kwargs)
1628|TypeError: prepare_token_request() got multiple values for argument 'grant_type'
1629|During handling of the above exception, another exception occurred:
1630|Traceback (most recent call last):
1631|File "/usr/local/lib/python3.7/dist-packages/requests_oauthlib/oauth2_session.py", line 484, in request
1632|url, http_method=method, body=data, headers=headers
1633|File "/usr/local/lib/python3.7/dist-packages/oauthlib/oauth2/rfc6749/clients/base.py", line 217, in add_token
1634|raise TokenExpiredError()
1635|oauthlib.oauth2.rfc6749.errors.TokenExpiredError: (token_expired)
1636|During handling of the above exception, another exception occurred:
1637|Traceback (most recent call last):
1638|File "/usr/local/lib/python3.7/dist-packages/websocket/_app.py", line 383, in run_forever
1639|dispatcher.read(self.sock.sock, read, check)
1640|File "/usr/local/lib/python3.7/dist-packages/websocket/_app.py", line 66, in read
1641|if not read_callback():
1642|File "/usr/local/lib/python3.7/dist-packages/websocket/_app.py", line 351, in read
1643|return teardown(frame)
1644|File "/usr/local/lib/python3.7/dist-packages/websocket/_app.py", line 318, in teardown
1645|self._callback(self.on_close, close_status_code, close_reason)
1646|File "/usr/local/lib/python3.7/dist-packages/websocket/_app.py", line 429, in _callback
1647|self.on_error(self, e)
1648|File "/var/www/html/plugins/gardena/resources/gardenad/gardena/ws_client.py", line 53, in _on_error
1649|self._set_connected(False)
1650|File "/var/www/html/plugins/gardena/resources/gardenad/gardena/ws_client.py", line 45, in _set_connected
1651|self._on_connection_callback()
1652|File "/var/www/html/plugins/gardena/resources/gardenad/gardena/smart_system.py", line 288, in
1653|self.gardena_ws_client = WSClient(on_message_callback=self.on_message, on_connection_lost_callback=lambda: self.on_gardena_ws_connection_lost(location=location), level=self.level)
1654|File "/var/www/html/plugins/gardena/resources/gardenad/gardena/smart_system.py", line 340, in on_gardena_ws_connection_lost
1655|self.start_gardena_ws(location)
1656|File "/var/www/html/plugins/gardena/resources/gardenad/gardena/smart_system.py", line 282, in start_gardena_ws
1657|data=json.dumps(args, ensure_ascii=False),
1658|File "/usr/local/lib/python3.7/dist-packages/requests/sessions.py", line 577, in post
1659|return self.request('POST', url, data=data, json=json, **kwargs)
1660|File "/usr/local/lib/python3.7/dist-packages/requests_oauthlib/oauth2_session.py", line 503, in request
1661|self.auto_refresh_url, auth=auth, **kwargs
1662|File "/usr/local/lib/python3.7/dist-packages/requests_oauthlib/oauth2_session.py", line 422, in refresh_token
1663|body=body, refresh_token=refresh_token, scope=self.scope, **kwargs
1664|File "/usr/local/lib/python3.7/dist-packages/oauthlib/oauth2/rfc6749/clients/base.py", line 475, in prepare_refresh_body
1665|refresh_token=refresh_token, **kwargs)
1666|TypeError: prepare_token_request() got multiple values for argument 'grant_type'
1667|During handling of the above exception, another exception occurred:
1668|Traceback (most recent call last):
1669|File "/usr/local/lib/python3.7/dist-packages/requests_oauthlib/oauth2_session.py", line 484, in request
1670|url, http_method=method, body=data, headers=headers
1671|File "/usr/local/lib/python3.7/dist-packages/oauthlib/oauth2/rfc6749/clients/base.py", line 217, in add_token
1672|raise TokenExpiredError()
1673|oauthlib.oauth2.rfc6749.errors.TokenExpiredError: (token_expired)
1674|During handling of the above exception, another exception occurred:
1675|Traceback (most recent call last):
1676|File "/usr/local/lib/python3.7/dist-packages/websocket/_app.py", line 424, in _callback
1677|callback(self, *args)
1678|File "/var/www/html/plugins/gardena/resources/gardenad/gardena/ws_client.py", line 53, in _on_error
1679|self._set_connected(False)
1680|File "/var/www/html/plugins/gardena/resources/gardenad/gardena/ws_client.py", line 45, in _set_connected
1681|self._on_connection_callback()
1682|File "/var/www/html/plugins/gardena/resources/gardenad/gardena/smart_system.py", line 288, in
1683|self.gardena_ws_client = WSClient(on_message_callback=self.on_message, on_connection_lost_callback=lambda: self.on_gardena_ws_connection_lost(location=location), level=self.level)
1684|File "/var/www/html/plugins/gardena/resources/gardenad/gardena/smart_system.py", line 340, in on_gardena_ws_connection_lost
1685|self.start_gardena_ws(location)
1686|File "/var/www/html/plugins/gardena/resources/gardenad/gardena/smart_system.py", line 282, in start_gardena_ws
1687|data=json.dumps(args, ensure_ascii=False),
1688|File "/usr/local/lib/python3.7/dist-packages/requests/sessions.py", line 577, in post
1689|return self.request('POST', url, data=data, json=json, **kwargs)
1690|File "/usr/local/lib/python3.7/dist-packages/requests_oauthlib/oauth2_session.py", line 503, in request
1691|self.auto_refresh_url, auth=auth, **kwargs
1692|File "/usr/local/lib/python3.7/dist-packages/requests_oauthlib/oauth2_session.py", line 422, in refresh_token
1693|body=body, refresh_token=refresh_token, scope=self.scope, **kwargs
1694|File "/usr/local/lib/python3.7/dist-packages/oauthlib/oauth2/rfc6749/clients/base.py", line 475, in prepare_refresh_body
1695|refresh_token=refresh_token, **kwargs)
1696|TypeError: prepare_token_request() got multiple values for argument 'grant_type'
1697|During handling of the above exception, another exception occurred:
1698|Traceback (most recent call last):
1699|File "/usr/local/lib/python3.7/dist-packages/requests_oauthlib/oauth2_session.py", line 484, in request
1700|url, http_method=method, body=data, headers=headers
1701|File "/usr/local/lib/python3.7/dist-packages/oauthlib/oauth2/rfc6749/clients/base.py", line 217, in add_token
1702|raise TokenExpiredError()
1703|oauthlib.oauth2.rfc6749.errors.TokenExpiredError: (token_expired)
1704|During handling of the above exception, another exception occurred:
1705|Traceback (most recent call last):
1706|File "/usr/lib/python3.7/threading.py", line 917, in _bootstrap_inner
1707|self.run()
1708|File "/usr/lib/python3.7/threading.py", line 865, in run
1709|self._target(*self._args, **self._kwargs)
1710|File "/usr/local/lib/python3.7/dist-packages/websocket/_app.py", line 386, in run_forever
1711|self._callback(self.on_error, e)
1712|File "/usr/local/lib/python3.7/dist-packages/websocket/_app.py", line 429, in _callback
1713|self.on_error(self, e)
1714|File "/var/www/html/plugins/gardena/resources/gardenad/gardena/ws_client.py", line 53, in _on_error
1715|self._set_connected(False)
1716|File "/var/www/html/plugins/gardena/resources/gardenad/gardena/ws_client.py", line 45, in _set_connected
1717|self._on_connection_callback()
1718|File "/var/www/html/plugins/gardena/resources/gardenad/gardena/smart_system.py", line 288, in
1719|self.gardena_ws_client = WSClient(on_message_callback=self.on_message, on_connection_lost_callback=lambda: self.on_gardena_ws_connection_lost(location=location), level=self.level)
1720|File "/var/www/html/plugins/gardena/resources/gardenad/gardena/smart_system.py", line 340, in on_gardena_ws_connection_lost
1721|self.start_gardena_ws(location)
1722|File "/var/www/html/plugins/gardena/resources/gardenad/gardena/smart_system.py", line 282, in start_gardena_ws
1723|data=json.dumps(args, ensure_ascii=False),
1724|File "/usr/local/lib/python3.7/dist-packages/requests/sessions.py", line 577, in post
1725|return self.request('POST', url, data=data, json=json, **kwargs)
1726|File "/usr/local/lib/python3.7/dist-packages/requests_oauthlib/oauth2_session.py", line 503, in request
1727|self.auto_refresh_url, auth=auth, **kwargs
1728|File "/usr/local/lib/python3.7/dist-packages/requests_oauthlib/oauth2_session.py", line 422, in refresh_token
1729|body=body, refresh_token=refresh_token, scope=self.scope, **kwargs
1730|File "/usr/local/lib/python3.7/dist-packages/oauthlib/oauth2/rfc6749/clients/base.py", line 475, in prepare_refresh_body
1731|refresh_token=refresh_token, **kwargs)
1732|TypeError: prepare_token_request() got multiple values for argument 'grant_type'
1733|[2022-06-13 12:33:10]DEBUG : Client connected to [127.0.0.1:43272]
1734|[2022-06-13 12:33:10]DEBUG : Message read from socket: b'{"action":"updateDevices","apikey":"J80dyr3huj1xZi27cT*****************"}'
1735|[2022-06-13 12:33:10]DEBUG : Client disconnected from [127.0.0.1:43272]
1736|[2022-06-13 12:33:10]DEBUG : Message received in socket JEEDOM_SOCKET_MESSAGE
1737|[2022-06-13 12:33:10]INFO : updating locations
1738|[2022-06-13 12:33:10]ERROR : Send command to demon error:prepare_token_request() got multiple values for argument 'grant_type'
1739|[2022-06-13 12:57:30]DEBUG : Signal 15 caught, exiting...
1740|[2022-06-13 12:57:30]INFO : Shuting down
1741|[2022-06-13 12:57:30]DEBUG : Removing PID file /tmp/jeedom/gardena/deamon.pid
1742|[2022-06-13 12:57:32]INFO : Starting daemon
1743|[2022-06-13 12:57:32]INFO : Log level: debug
1744|[2022-06-13 12:57:32]DEBUG : Socket port: 55070
1745|[2022-06-13 12:57:32]DEBUG : PID file: /tmp/jeedom/gardena/deamon.pid
1746|[2022-06-13 12:57:32]DEBUG : Init request module v2.27.1
1747|[2022-06-13 12:57:33]INFO : Authentication done
1748|[2022-06-13 12:57:33]INFO : updating locations
1749|[2022-06-13 12:57:33]DEBUG : opening websocket for location My Garden
1750|[2022-06-13 12:57:33]DEBUG : Connect Websocket to wss://ws-iapi.smart.gardena.dev/v1?auth=*****
1751|[2022-06-13 12:57:33]DEBUG : Checking websocket connection status in 30s...
1752|[2022-06-13 12:57:33]INFO : updating devices for location My Garden
1753|[2022-06-13 12:57:34]INFO : Websocket connected
1754|[2022-06-13 12:57:34]INFO : Syncing known devices with jeedom
1755|[2022-06-13 12:57:34]DEBUG : Send to jeedom : {'smartsystem_location': {'id': '**', 'name': 'My Garden'}}
1756|[2022-06-13 12:57:34]DEBUG : Send to jeedom : {'smartsystem_device': {'id': '**', 'type': 'MOWER', 'battery_level': 70, 'battery_state': 'CHARGING', 'name': 'Robert', 'rf_link_level': 90, 'rf_link_state': 'ONLINE', 'serial': '**', 'model_type': 'GARDENA smart Mower', 'location_id': '**', 'activity': 'OK_CHARGING', 'operating_hours': 201, 'state': 'OK', 'duration': 0, 'last_error': 'N/A', 'battery_type': 'Rechargeable'}}
1757|[2022-06-13 12:57:34]DEBUG : new message received in Websocket: {"id":"**","type":"LOCATION","relationships":{"devices":{"data":[{"id":"**","type":"DEVICE"}]}},"attributes":{"name":"GARDENA smart Garden"}}
1758|[2022-06-13 12:57:34]DEBUG : Received message LOCATION
1759|[2022-06-13 12:57:34]DEBUG : new message received in Websocket: {"id":"**","type":"DEVICE","relationships":{"location":{"data":{"id":"**","type":"LOCATION"}},"services":{"data":[{"id":"**:cbtg","type":"MOWER"},{"id":"**","type":"COMMON"}]}}}
1760|[2022-06-13 12:57:34]DEBUG : Received message DEVICE
1761|[2022-06-13 12:57:34]DEBUG : Send to jeedom : {'smartsystem_device': {'id': '**', 'type': 'MOWER', 'battery_level': 70, 'battery_state': 'CHARGING', 'name': 'Robert', 'rf_link_level': 90, 'rf_link_state': 'ONLINE', 'serial': '**', 'model_type': 'GARDENA smart Mower', 'location_id': '**', 'activity': 'OK_CHARGING', 'operating_hours': 201, 'state': 'OK', 'duration': 0, 'last_error': 'N/A', 'battery_type': 'Rechargeable'}}
1762|[2022-06-13 12:57:34]INFO : Start listening
1763|[2022-06-13 12:57:34]DEBUG : Socket interface started
1764|[2022-06-13 12:57:34]DEBUG : LoopNetServer Thread started
1765|[2022-06-13 12:57:34]DEBUG : Listening on: [localhost:55070]
1766|[2022-06-13 12:57:34]DEBUG : new message received in Websocket: {"id":"**:cbtg","type":"MOWER","relationships":{"device":{"data":{"id":"**","type":"DEVICE"}}},"attributes":{"state":{"value":"OK","timestamp":"2022-06-13T12:36:05.406+00:00"},"activity":{"value":"OK_CHARGING","timestamp":"2022-06-13T12:36:05.406+00:00"},"operatingHours":{"value":201}}}
1767|[2022-06-13 12:57:34]DEBUG : Received message MOWER
1768|[2022-06-13 12:57:34]DEBUG : Send to jeedom : {'smartsystem_device': {'id': '**', 'type': 'MOWER', 'battery_level': 70, 'battery_state': 'CHARGING', 'name': 'Robert', 'rf_link_level': 90, 'rf_link_state': 'ONLINE', 'serial': '**', 'model_type': 'GARDENA smart Mower', 'location_id': '**', 'activity': 'OK_CHARGING', 'operating_hours': 201, 'state': 'OK', 'duration': 0, 'last_error': 'N/A', 'battery_type': 'Rechargeable'}}
1769|[2022-06-13 12:57:34]DEBUG : new message received in Websocket: {"id":"**","type":"COMMON","relationships":{"device":{"data":{"id":"**","type":"DEVICE"}}},"attributes":{"name":{"value":"Robert"},"batteryLevel":{"value":70,"timestamp":"2022-06-13T12:56:13.195+00:00"},"batteryState":{"value":"CHARGING","timestamp":"2022-06-13T12:36:05.406+00:00"},"rfLinkLevel":{"value":90,"timestamp":"2022-06-13T11:58:11.125+00:00"},"serial":{"value":"**"},"modelType":{"value":"GARDENA smart Mower"},"rfLinkState":{"value":"ONLINE"}}}
1770|[2022-06-13 12:57:34]DEBUG : Received message COMMON
1771|[2022-06-13 12:57:34]DEBUG : Send to jeedom : {'smartsystem_device': {'id': '**', 'type': 'MOWER', 'battery_level': 70, 'battery_state': 'CHARGING', 'name': 'Robert', 'rf_link_level': 90, 'rf_link_state': 'ONLINE', 'serial': '**', 'model_type': 'GARDENA smart Mower', 'location_id': '**', 'activity': 'OK_CHARGING', 'operating_hours': 201, 'state': 'OK', 'duration': 0, 'last_error': 'N/A', 'battery_type': 'Rechargeable'}}
1772|[2022-06-13 13:04:16]DEBUG : new message received in Websocket: {"id":"**:cbtg","type":"MOWER","attributes":{"state":{"value":"OK","timestamp":"2022-06-13T12:36:05.406+00:00"},"activity":{"value":"OK_CHARGING","timestamp":"2022-06-13T12:36:05.406+00:00"},"operatingHours":{"value":201}}}
1773|[2022-06-13 13:04:16]DEBUG : Received message MOWER
